done with old pump
mdrhom1
i have a 1984 vip boat with a mercruiser drive last couple years ive had alot of problem with trim pump raising but not lowering pump runs fine both directions just wont go down i take it apart a few times clean it mess around for a few days and finally get it working this year ive had enough of it but cant seem to find part number for replacement its the square bottom pump all aluminum with valve body on bottom with 2 lines on it. ive been looking at a few pumps and really dont see any difference other than side fill is on. or steel or stainless steel mount all seem to be the same pump maybe have to come up with adaptors thanks guys for any help also i did pull my old pump and cant find any part numbers
mdrhom1
Re: done with old pump
thanks its the prestolite pump part number 14336A17 but still does not match closest is number 14336A9 in the marine store which croses to Part # 18-6752 would this be correct thanks
mdrhom1
thanks i did a search in the marine store and that one didnt even come up thanks again
