chistedude
- Apr 2, 2013
- 9
Hey everybody
Kinda a newbie here, but I've been coming here for answers for quite some time. This is the third season I've had my 01 bayliner with a 3.0 mercruiser. Decided to give it a good overhaul before the season, rebuilt the card, replaced spark plugs distributor cap and rotor. Went to change the oil but the drain plug was completely corroded so I had to drop the oil pan, oh ya big mess by the way. So I get everything back together and go to start er up but no fire. Through a little investigation I realize I'm not getting fuel, I took the fuel line off the Carb turn it over a few times, no fuel. Come to find out I knocked my fuel filter off when removing my oil pan. Went and bought a new filter while I was at it, get that put on try to turn it over a few good many times, still no fuel spitting out. My fuel pump was working as of last July, and I've heard those mechanical pump are pretty solid. So I put some gas in a bowl as a remote fuel tank and put the line into it to see if it'd suck it up but no luck. So now the only thing I can assume is the pump went bad. Do pumps usually go bad like that by sitting? I know its a 12 yr old pump so I don't have a problem replacing it, I just can't believe it'd just go out. But ya, anyways, my question after making y'all read all of that is this. As I was trying to figure this all out I happened to blow air into the line going into the pump from the tank. The air makes it all the way to the end with the Carb and I hear a slight buzzing vibration noise coming from the fuel pump. Would this be normal? (not saying its normal to blow air into the pump) but would the air normally be able to make it past the pump or is that a good indication that the pump is bad?
Thanks for listening, feel free to chime in if u have any thoughts on the matter.
