Re: Doind away with the oil pump?
if the fuel side is working fine, just unplug the sensor on the oil tank, and the VRO pump, cut the oil line about 3 inches from the motor connection plug and clamp it. the fuel side will continue to pump premixed fuel. also mix you fuel 50-1, then remove the fuel line to carb, and pump bulb, till you get mixed fuel there. the fuel will change colors.
