bigboat606
Thread starter- Joined
- Sep 6, 2009
- 52
I am installing the flywheel on a 1987 200 HP Evinrude. The manual states to position the Woodruff key so that the outer edge of the key is vertical. When I removed the flywheel the outer edge of the woodruff key was positioned parallel to the tappered crank shaft. I does not stick out too much above the crankshaft but enough to align the flywheel. My question is how important is it to position the woodruff key vertical where it would stick out much more? I ask because the key is stuck in the crankshaft slot. Really stuck! I bent a screw driver trying to remove it, so I stopped, thinking I might do damage to the slot. But if it needs to be repositioned then I will. Thanks for your response in advance.
