Does this work?
dodgyd
After spending some time searching this forum, I have come up with the following for my wiring diagram. The boat is 19 feet with a 2004 Yamaha 200 hp. Will this work? Any improvements to make?
Points to note, ?S? means switch so there will be only three switches for the bilge, nav lights and 12v socket. A is where the wire goes off the page and joins up with the A on the other side to make the diagram neater.
The battery switch will be put on both most of the time, but if i am sitting at anchor for an extended period, I would switch to batt 2. If batt 2 goes flat, I can still start on batt 1 and make it home.
fish_on_the_deck
Re: Does this work?
I like it!
One tiny thing... the NAV/Anc lights. You mean you have two positives running to the stern? one for when the switch is down (on "anc") and the other for when the switch is up (on "Nav")?
It can easily be done without having to do that... either a SPDT switch with a diode, or a DPDT switch with a jumper would work.
Maybe show the bow and stern light separatly in the wiring diagram?
sasto
Re: Does this work?
Having wired boats from 16' to 65' I have come across many diagrams. Yours looks fine. We almost always wired the BP to a dedicated battery....especially smaller boats. I found for my application...single engine/duel battery.. w/switch.....I wired the BP to the common on switch as with all other options, instead. I leave the battery switch on while at the dock. (If you run down batt. 2 the pump will no longer have the power it needs to operate.) Then switch batteries and have full power to the BP. I did this only because it works the best for me....I think. Any thoughts?
Silvertip
Honorary Supreme Mariner
Re: Does this work?
The point of having an OFF position on the dual battery switch is to actually kill everything so you DON'T end up with two dead batteries in the event you left something on. The safe way to do it is to wire the BP directly to the house battery. It doesn't matter if you leave the switch on -- the battery will still be dead if the BP runs frequently enough to run it down. With the switch OFF the battery doesn't have to deal with the operators "forgetfulness".
sasto
Re: Does this work?
Thanks Silvertip...I Understand...but...I'm to anal to leave anything on...haven't yet in years...but getting sometimers disease. Say for research that nothing was ever left on, wouldn't this be the prefered method. I'm not really suggesting this method to others but I'm thinking this works well for me. I check the boat every morning and run her in the evening and if for some reason the BP would drain down my battery I can simply switch to the other battery and not have to parallel the batteries. Any input or debate is appreciated. Don't want to hijack this thread.
fish_on_the_deck
Re: Does this work?
Say for research that nothing was ever left on... Any input or debate is appreciated. Don't want to hijack this thread.
well... if you were are more concerned about having roughly twices as much time before your BP runs out of juice, than you are about accedentially leaving leaving a device on and running both batteries dead, then I'd choose your setup.
My situation is that I trailor my boat, and rarely leave it in the water unattended for more than a couple hours, so my preference (as I think most would) is to have it on the house batt +, and turn the switch to OFF when not in use.
If I were leaving my boat at the dock and inclement weather was coming... i'd make sure I turned eveything off, and leave it on COM.
Like you said... each situation is different, but I think you're in the minority here.
Silvertip
Re: Does this work?
Although battery switches are installed in some pretty creative ways, it always puzzles me as to why folks bother because very many of those configurations defeat the purpose of having the switch and in some cases can create more of a problem than not having one at all.
sasto
Re: Does this work?
I'm sure I am in the minority....I run a 65' and a 35' sportfish and I have never turned the batteries off except for service. Those boats have an electrically controlled parallel switch that I can use if a bank is low. On the boat I'm speaking about here is different. I use the switch to charge the battery of my choice. She is an old boat, does take on some water thru packing gland and other sources that haven't been issued yet. I feel safer if something would happen where I can't get to the boat after a couple days of hard rain, I can have a friend switch the batteries over. Considering installing a switch at the helm to select which battery I want my BP to run off of. Not ideal....but suits my boating needs at this time. :cool:
dodgyd
Re: Does this work?
This is the way that I have it in the diagram... right?
The boat lives on a trailer, but the plan is to wire it so that if it is left in the water overnight, I can turn the batteries to off and the bilge is still ready to go using battery 2. If the storm clouds are coming, then I can turn the battery switch to both, make sure every thing else is off and the bilge can run till both batteries are flat.
Just to be crystal clear, is this the same view as Silvertip and what I have above?
dodgyd
Re: Does this work?
Hmmm, I hadn't quite figured out the plan here and you caught me out!! My main issue is that I don't like the idea of the centre off switch. I would rather flick all switches up (or down) and know that everything is off. This is especially good if a few different people drive the boat.
What about using two switches side by side, have a master on off for the nav lights and then a second switch to toggle between anchor light and full nav lights?
If using a diode (which is a top idea), it could be placed on the anchor / full nav toggle switch (I think). I will have a go a diagram.
Edit:
There is no -ve showing and I know my switch drawings don't confirm to standards but how does this look for the nav / anc lights if I want to go with a master switch then a toggle between anchor / nav (including gauges)
dockwrecker
Re: Does this work?
My BP jumps both batts, and I use a shorepower charger/tender as my boat is on the water 6 months of the year. The trick here is the float switch and keeping it free and clear of debris and checking it's function regularly. Yes it's technically "ON" but it should be. If the switch is functioning properly, it's not a draw unless needed. Should I have an extended visit from my boat, the last thing I want is to worry that rain or a leak has filled the bilge. Your setup looks fine for a trailer boat scenario.
fish_on_the_deck
Re: Does this work?
Yeah, you have it right... the float switch is wired to the Batt 2 terminal on the battery switch... this is the same as being on the batt 2 positive.
As far as the bilge pump wiring is concerned, I agree (and is in line with what silvertip said) with what you have in the original post.
fish_on_the_deck
Re: Does this work?
your diagram would work (but not how you describe) if you insist on going that route. I don't see why it would be difficult to leave it in the center... especially if your switches have an indicator lights like mine do. And especially again if you plan to turn the battery switch off after use like you said above.
Try these guys for switch panels if you want to just have it made for you instead of scrounging around for the parts, and trying to get it all right... SWITCH PANELS. Talk to Eric there... if you email him he will wire it up however you want.
But... its your boat. Your diagram would work in the fact that all switched down = "all off", but the master switch would always turn the anchor light on... not a master and the second switch alternateing between the two as you descried. In that case you're really just looking for the original setup (either DPDT or DPST with diode), with the input being switched by a SPST.
