Re: does octane matter?
Well, I don't know about less gasoline per gal>>>>I remember reading about higher volitility of lower octane fuel>>tends to burn faster & can detonate much easier. If I remember correctly, when distilled (or CRACKED)oil is broken down by hydrocarbon weights> Methane>1 carbon,Propane 3 carbon atoms, Butane 4 carbon atoms,ect>>>Gasoline's volital components where broken into octane (8 carbon atoms) & heptane(7 carbon atoms)>>>octane allows greater compression before spontaneously igniting(detonation). Heptane flashes with little compression. An 87 octane rateing means the gas contains 87%octane & 13%heptane.>>>NOT MORE GAS OR LESS<br />As for using higher ratings>>>follow the manufacturers suggetion>>>Except maybe remember>>>most Plus fuel and Prem. fuels have more detergent additives. I know my car (Mercury grand Marque, dual overhead cam V8 calls for 87 octane>>REGULAR. But after the upper half of the engine had to be pulled apart at the dealer because of sever carbon buildup>>>they recommended that we use 89 octane fuel. Something to think about.
