MikeDobbs
- May 8, 2015
- 206
Hey everyone,
So I just finished installing my new manifold and riser. This is the first time I have had the engine running since adjusting the valves as per the manual (the 3/4 of a turn past zero lash thing).
It definitely sounds much better to me than it did before the adjustment, but I do still hear a noticeable ticking/clicking/tapping noise. What I'd like to know is whether this is a reasonable noise for a Mercruiser 3.0lx circa 1998 with about 300 hours, or if this is a problem that I should be attending to. If you suspect the latter, I would welcome any suggestions as to what the problem might be or how I should proceed with fixing it.
Here's the video from today: I have it at idle for a bit at first, then bring it up to about 2000. The sound is quite a bit more pronounced at 2000 RPM than at idle
