doel fins
joblo33
My uncle gave me some old hydrofoils off his volvo penta outdrive to put on my Merc and luckily the holes that were already in my leg line up. I have a 16ft aluminum and a 16 pitch prop, do you think I'd gain anything by installing them? I'm probably going to give them a shot tomorrow anyways unless I hear otherwise.<br />Eric
roscoe
Re: doel fins
They may help, and they may hurt your performance.<br /><br />If your motor is mounted at the correct height and you are not underpowered, you will likely see little effect.<br /><br />If your motor is mounted at the correct height, but you are underpowered, it should help holeshot and planing.<br /><br />If your motor is mounted too low, it will likely slow you down.<br /><br />If your motor is mounted too high, it will have little to no effect.<br /><br />Give them a try.<br />Water should not flow over the top of them once you get on plane.
