Do you stop to help stranded boaters?
jay_merrill
Re: Do you stop to help stranded boaters?
There are cleats and there are cleats - some will handle the stress of towing and some won't. If in doubt, don't use them.
Generally speaking, stern eyes and bow eyes are the way to go. The hull thickness in the affected areas tends to be thicker and stronger than the deck positions that cleats are usually mounted on. Stern eyes and bow eyes are also usually backed better, which is an important consideration.
No matter what you are using as a towing point, don't try to tow the boat too fast. You may be sure of the strength of you own eyes, but the boat you are towing is often an unknown quantity. The worst scenario that you can run into, is to have the boweye or a cleat on the other boat give way. If you have excessive strain on the line, it will then recoil and whip towards you with a chunk of metal on the end. Simply put, if it hits you in the head, you may not live to tell about it.
Towing slowly will also prevent damage to your own motor, as well as minimize fuel consumption. Towing at 2,500 to 3,500 rpm, with a big bow wave in front of both your boat and the boating being towed, will cause high manifold pressure, alot of heat and stress on your motor, and high fuel consumption.
It doesn't take much hp to tow a boat through calm water at slow speeds. I have actually towed a 30 ft boat with a 15' trihull that had a pair of 6hp Johnsons on it. That is not something that I would normally attempt, but I found the guy caught up in a submerged gill net. He had two little boys with him on a fall day and the temperature was dropping rapidly, as the sun set. I cut him out of the net and then took him under tow to get him back to the ramp/harbor. We made all of about 2 knots, but I got them to safety.
In short, if you use common sense and a high level of attention to safety, you can get the job done in just about any situation.
jbjennings
If I see someone having engine trouble or such, I try to drive by at a reasonable distance nice and slow and ask "Need any help?". If so, I tow. If not, I go my merry way. I would think if a person WANTED some help, they'd wave their arms or something to signal me that they needed my assistance. I can understand why folks would sometimes pass you by, thinking that you didn't want to be bothered. If you want help, sometimes you gotta ask for it.:) I TRY to always have more fuel than I need in case I have to help someone out. I also try to carry a couple of tools and such, in case myself or someone else needs to borrow one.
Good manners don't cost me anything!
JBJ
Plainsman
Yes I do. I also help out at the dock too.
rjlipscomb
Boating on Lake Mead yesterday and found two sets of stranded jet skiers. The 1st on my way out. He needed to borrow tools to clear the tow line caught up in his jet drive. That may be the last time I lend my tools since I got the tool case back wet and full of sand (not a stainless steel set). The 2nd ski was out of gas and needed a tow. Glad to help.:)
Pierutrus
YES, and.....
Holding orange flag straight up/stationary means, person/skier/tuber, down in the water.....
Waving orange flag back and forth means, distress/trouble.
And a blow horn helps as well.
Any other :confused:
And on Lake Mead, when it's 115*, if you even think somebody is having a problem, stop and check it out because their lives depend on it.;)
Pierutrus
Now Jet Fleas on the other hand.........
Forget what I posted above.:eek:
I'm only kidding.:p
rjlipscomb
Yeah, you've got to stop and lend assistance on Lake Mead when possible. The sun will bake you crisp fast. The girl on the jet sky (out of gas) was definitely worth the stop! :p The guys stranded on the beach, they were not in danger... but, appreciated the help.
jay_merrill
Thanks.
Shrimping is a common occupation where I live and we have a local supplier of nets, winches, floats, etc. I custom made the towing harness, including all of the splicing, to fit my boat exactly.
The bridle is just long enough to provide clearance around the motor, but is too short to drop down to the level of the prop. The floats assist with this, as well. In fact, I can actually back the boat down a little bit, without having to worry about the line fouling. You may also notice that I didn't use a block on the tow line, where it meets the bridle. While having one would allow the line to move on the bridle more easily, I didn't want to have weight there, because of the tendancy it would have to cause the line to sink. I do, however, have to inspect the line for wear frequently.
One other thing that I did for towing, is to install cleats along the rails, at "the thirds." By having them 1/3rd and 2/3rds of the distance between the bow and the stern, on both sides of the boat, I can take another boat in a side tow easily. These cleats give me a place to run spring lines, so that I can keep the towed boat in control. I don't do side tows that much, but sometimes I need to, so that I can position the boat on the rear roller of a trailer for retrieval.
