Do you or do you not attach yellow wire to gray wire for CDI electronics, force 40.
kjprag01
Yes or no? From the Statror there are two yellow wires connected to the Voltage Regulator by two yellow wires. The gray wire from the voltage regulator is the tach signal, should people daisy chain a yellow wire to the gray wire to a yellow wire for tachometer function, assuming voltage reg stat are working correctly.
