Hi, I have been reading your questions for several weeks in anticipation of rebuilding a '74 Sears (Arrow Glass) 14' aluminum flat bottomed jon boat. I was working on another boat but couldn't turn this deal down. To make a long story short, I am removing all of the outside paint down to bare aluminum, sanding/sand blasting it and recoating all of the outside it all with epoxy then marine top paint. Maybe using fiberglass cloth on the hull and transom just to stop any potential leaks. The transom has two typical (knee) braces that were put on durning the last restore. Unfortunately, they were put in through the wood with ss screws but regular metal through the hull and were a rusted mess before I took them out. I am also replacing the wood.
My question to all you boat builders out there is this, do I need to put both braces back on? Will one (mid-way between the starboard side and the middle of the transom) give me enough support? If I only use one, I will have a perfect spot for my 6gal gas tank next to the transom. I have a '80 Evinrude 15 waiting to be bolted up. I can certainly cover the screw holes in the hull with epoxy and fiberglass cloth. I appreciate being a new member to this site and would appreciate any guidenance or opinions that you might offer. Thanks.
