Do I need thrust washer for new prop?
Drybo
'91 115 mercury 2 stroke/ 13x19 pitch. <br />prop is quicksiler. <br /><br />Want to order new stiletto ss 13x19 prop but instructions say I need new thrust washer. Do I need a new washer?
stevens
Re: Do I need thrust washer for new prop?
Depending on what you have, you may not need the forward one, but probably the aft one.<br /><br />Here's a picture of all the parts I think you need, apart from the prop itself:<br /><br />
<br /><br />The complete set is about $41 here at iboats, or $46 over at Overton's. Better double-check though, that you get the right parts for your engine and prop.
Drybo
Thanks Stevens, I have the new nut and lock washer<br />think I need that thrust washer in upper left of photo, but will double check. Thanks again for help.
Realgun
The prop housing might be longer than standard and you need a thinner washer to compensate.
