Do I have the right prop or should I change?
fstss10
I just purchased a 92 Crownline 196BR. I installed a new 5.0 w/ 4bb. It has an Merc Alpha I drive. It currently has an Atwood Ballistic 17 degree prop part # 345132. I've heard these props are junk and the boat seems to be slow to plane out. It also turns 4000 rpms at full throttle.
Tail_Gunner
Re: Do I have the right prop or should I change?
You need to check your tach...or something esle is wrong. a 5.0 with a 4bl carb should do more than 230-240 hp...on a 20' boat with a 17 that should get 5000...seems that ballistic has some bite..:D
Your right though there not a I/O prop normally...thats normally...;)
steelespike
imo,A 17 should over rev and approach close to 50.Without rpm and speed
can't really tell where the fault might be.
