Do I have correct replacment prop for Alpha one drive 3.0, how do I install if I do?
jfallen
I purchased Solas Amita #1511-145-19 Aluminum Boat Propeller,
When removing my current prop, it is a flo torque thrust master II design.
The new Solas will fit the shaft, but I cannot tighten the hub nut to 55lb torque, without locking the propeller,
to where it does not turn freely, or as free as the original.
My question is do I have the correct propeller for this design?
If I do, how do I tighten the nut and allow the propeller to turn freely?
SkiDad
sounds like you are missing the thrust washer that goes on before the prop.
jfallen
Mitzyman, you are coorect, I went to you tube and figured it out, it was stuck to original prop.
Put it on and fits fine.
