do factory sending units work with aftermarket gauges?
turbocorrado
got a 1997 wellcraft eclipse and the tach and water temp gauges are broken, will the stock sending units for those gauges work with faria guages or do i need to order new sending units
kjsAZ
yes, the sender values are standardized. However, US/North America uses a different standard than the rest of the world. If you have a US made boat and buy gauges in the US they will fit.
One exception are the senders for trim/tilt. There you have to buy for the correct drive.
  • Sending-units-resistance-values_Faria.pdf
Ayuh,.... The Tach, get's it's signal from the coil's (-) terminal,....
The water temp senders are compatible,...
turbocorrado
you guys know where to find a 3.5" tach?? mine is measuring 3.5" and i can only find 3 or 4"
bruceb58
A 3" tachometer isn't necessarily 3"!
turbocorrado
thanks, i found the dimensions on faria's page. ended up needing a 4" tach
