I just purchased a 2000 Four Winns Horizon 200 with a Penta 5.0 GL, PEFS. The boat has been sitting for a while and need some TLC before use. Main issue to get motor running is ignintion. I have through reading the manuals etc figured out it has the BID prestolite ignition. The distributor has corroded a bit. I took it apart and after cleaning it is in good enough condition to be used except for the springs controlling ignition timing. Volvo part # 3853858. I also found a crossreference to OMC # 985625. My issue is that this part is no longer available. The only way to get the springs is to buy the complete distributor which I would prefer not to do. The springs are really simple, if I had a 'good one' I could probably go out and find a generic ones that would work. Any tips of
1) where I might find some of these springs hiding
2) what I could use instead
3) I was thinking I might try locking the timing in one position just to see if I can get the motor running (for a few seconds). Are there any reasons why I shouldn't?
Thanks,
Henrik
Thanks,
Henrik
