DISTRIBUTOR CAP of 302Ford V8 Engine
cher6417
HELP! HELP! HELP!
There is a MOISTURE BUILD-UP in the DISTRIBUTOR CAP of my 302 Ford V8
Engine on my 32' Slickcraft Boat. IT WILL NOT IDLE DOWN! What is causing the problem????? Thanks C&D
JB
Re: DISTRIBUTOR CAP of 302Ford V8 Engine
As far as I know, cher, Ford never made a 302 V8 outboard.
I will move this for you.
newport dave
Your centrifical advance mechanism may be frozen up or the springs may be bad causing the timing to be too far advanced at idle. I would suggest rebuilding or replacing the distributor.
Ayuh,...
And to add to Dave's advise,....
1st thing that should be done,.. Is the find Where the water is coming from,+ Get it Stopped....
WizeOne
HELP! HELP! HELP!
Wipe out the moisture. Spray it with a electrical contact cleaner. It is not uncommon for moisture to build up (depending on atmospheric conditions) even on a vented marine distributor.
If it continues to re-appear, rapidly, then that is a different issue that I do not have a ready solution for.
