aguitarestv
Thread starter- Joined
- Jun 20, 2007
- 51
i have a 1969 johnson 115, and when the motar heats up to opperating temp. when you push the trottle wide open the distributir advance arm does not advance. i have pulled the flyweel and replaced the wearable nylon ring on the distributir base plate,coated it in 2 stroke oil. i have also disasembled the whole arm cleaned, and coated that in 2 stroke oil. when the motar is not running, or still cool, it workes perfectlly, so i dont understand why at opperating temp. it binds up and i have to advance it by hand. the motar does not overheat and has new waterpump,thermostate, ehaust housing gasket,and has 120 compresion in all 4 cylanders. i dont know if the bearings on the camshaft are gone and causing the center of the motar to heat up and binding the distributar or what. i have been having this problem for 2 plus years and no one can figure this out. please help!
