SeaKaye12
Thread starter- Joined
- Jul 3, 2005
- 1,116
Hi,<br /><br />Well; the time has come for me to go in search of a good transmission mechanic to do a "drain" and refill on my two Fords...a '98 Mustang GT and a '98 F-150. Both with the AR70W Transmissions.<br /><br />But; what to do? Different shops do different service.<br /><br />Some "suck" the old fluid out and replace via the dipstick tube. <br /><br />Others drop the pan to drain...then refill.<br /><br />Others un-hook the coolant line and hook up a pump and "flush" out the system...while leaving the pan installed.<br /><br />Still others drop the pan...and then "flush" with the new fluid feed at the pump.<br /><br />Then; there are the above methods prefaced with solvent type cleaners used prior to the flushing.<br /><br />I'm confused.<br /><br /><br />I'h hoping that a discussion here will get to the bottom of what's needed...and what's not...and what should be avoided.<br /><br />Thanks for reading, Chuck
