disconnecting shift shaft from 40hp 2001 johnson outboard mod. J40VLS1B.
aloha boy
Hi I am a new member for I have been trying to disconnect the shift shaft on this motor which happens to be a Johnson light brand (not commercial). SO it seems that they have made it very difficult to find where to disconnect the shift shaft. I have taken the lower cowling off and the starter. I can see the shaft connection under the carb but the bend in the shaft tells me that it should not be removed and there is a couple of bolts to disconnect so I don't think this is where it is to be disconnected. I looked at the water intake and its too small to access a connector. The only place I would think it would disconnect is at the 3 bolt flange just above the gear housing where I can see the shaft entering. But afraid to dismantle for fear of dropping something I shouldn't. I have watched a ton of utube videos for similar year models and all are much easier to access and disconnect. I suppose they are the commercial models. I have the Seloc 1990-01 repair manual but it has only general information on the 40hp.
Any suggestions would be most appreciated Thanks a bunch!
F_R
Honorary Supreme Mariner
Can't find that exact model number, but what I do find is simple enough. A bolt through the lever at the top end of the shift rod. Remove it and separate the lever, releasing the shift rod off the pivot pin. But maybe you have something different??
aloha boy
Hey thanks F_R sorry for the delay in responding to your reply but I was confused as to how to do it until I logged in again. Yes you were right there was a small bolt at the top of shift rod that I disconnected and it dropped the lower unit. I had to drop both lower cowling to get to the bolt as it is a tight space. Got the impeller replaced so good to go.
