Kickin Bass
Thread starter- Joined
- Aug 31, 2003
- 4
My manual is unclear on how to do this.<br />I replaced my head gasket and am trying to replace the impeller. I separated the shift rod at the water inlet screens and dropped the gearcase. I took the water pump apart but I can't slide the water pump plate over the keeper nut on the end of the shift rod. I assume that I need to unhook the shift rod at under the powerhead??<br />Also the water tube came out of the powerhead.<br />Do I need to use a sealer when re-installing it.<br /><br />Thanks in advance, Andy
