Dipstick warmer for winter storage
crazy charlie
Anyone ever use a dipstick warmer during winter storage?????I was considering trying it to cut down on the condensation that gets all over the outside of the motor when the day warms up a bit after a cold night.I would consider it in addition to all of the winterizing steps,not in place of any.Charlie
Boomyal
Re: Dipstick warmer for winter storage
interesting proposition for the condensation. If no one with experience responds it might just be worth a try. I have the same problem and over time it causes rust to appear that may never show up. Are they thermostatically controlled? Do you think they would get it hot enough to do the job. Don't forget that condensation is formed when cold moist air comes in contact with a relatively warmer object such as the engine block having store the heat from the day.<br /><br />I've thought of mounting a small fan in the engine compartment but no readily available fan is fit for continuous duty.
CCrew
Curious question.... <br /><br />Along the same lines, would it be feasible to use a block heater to maintain a consistent temp? Never seems to have any issues with my diesel tow rig..
Ralph 123
I was also thinking of block heaters this year. Has anybody tried them?<br /><br />Read about one guy who tried using space heaters and burnt his boat to the ground...
Boomyal
As Crazy Charlie said, I wouldn't use it in lieu of proper draining. It would probably keep the water in the motor from freezing but probably would not extend out to the water in the exhaust manifolds. Besides, what if you had a power outage.<br /><br />My interest remains in the condesation factor. Both exterior and in the cylinders.
Ralph 123
bubbakat
I use dip stick warmers on all my auto and small tractors works great for what you are looking for and I also use block warmers for all my diesel using motors
Boomyal
Ralph: The JCW, or any blanket for that matter might work real well for condensation. I might give that a try along with a dipstick warmer.<br />On the heaters, I wouldn't use that in an engine compartment. To much chance of fire. But I use something similar in my vehicles. Both my daughter's car and my work van sit outside all year. I have run extention cords thru the firewalls and out to the grilles. I've rigged up extention cords from a timer in the garage, run them out under the doors, then hang them up on a nail atop the garage door outside. When I pull up at the end of the day I grab the cord off of the wall and plug it into the cord at the grill. Around 5 am the heater sitting on the dash comes on and by the time I come out at 7 am there is no snow, ice, frost or dew on the windshield. Dry and clean. I unplug the cord, hang it up on the nail and I'm off for the day. Chill is off the interior too. I got the little 2 temp heater at Camper World. About $35 a couple of years ago. It's called Big Heat 6200. A local plumbing/electrical supply company has them in the winter also.(hope they don't kick me off the boat forum for this)<br /><br />Bubbakat:<br />you think those dipstick heaters would work well in a boat engine compartment? Cars have a lot more air circulation under the hood than a boat would and air circulation helps with condensation.
bubbakat
yea they would work alright in there. They dont keep the oil very hot just luke warm.
crazy charlie
From the general opinions,I think if i can find dipstick heaters I will give them a try.a little warmth is all i am looking for. Charlie
lukester
There is a product out there called a Golden Rod, it is used in the motorcycle/hot rod world for keeping condensation/mildew away when in storage.It is electric, plugs into an outlet and keeps the moisture away. Ihave had mine for years and the bike comes out shining every spring. I think I bought mine from Dennis Kirk Inc. about 15 years ago.
crazy charlie
By the way,for the cabin during storage i leave 2 fans on a timer and have them go on for a couple of hours a day and this works great!!!I leave the boat plugged in with the batteries in so I can charge them a few times a month.i plug the timer in to the outlets in the cabin.I also place a small heater on the stove top and turn it on to heat the cabin several times during storage never leaving it unattended.I have been able to do a few jobs inside the cabin quite comfortably when it is freezing outside. charlie
crazy charlie
Looks like i may have a snag---I have one of those extra long dipsticks(on my boat motor that is)(sorry girls).I will have to measure the length to see if the heater will reach the oil.Heck!!THERE IS ALWAYS A SNAG!! charlie
A Simple 60W Light Bulb will Do More for you......<br />Gheezzeeessss....... The Power Companies are going to Love you guys......<br />Block Heaters are 1500Watts.....<br />Heat..24/7.....<br />I Think You're All Crazy.....
crazy charlie
I would count out a block heater,it just is in no way necessary.The dipstick heater on a timer cant use much juice and may keep the afternoon condensation off of the block.I have seen times where the temp rises into the 40s or 50s during the day and the block stays colder and gets condensation all over it and come evening when the temp dips,the condensation freezes on the block.I would like to believe it but I dont see a lightbulb doing the same job.I know it is all overkill,but it is a small effort with a benefit.Count me in!!! Charlie
