My trim sender stopped working shortly before the end of last season, a visual inspection showed that one of the wires had broken close to the sender. New sender was ordered to be installed whilst I had the outdrive off for new seals.
I tested the new 3 wire sender and it reads correctly as expected. I set the sender to 11ohms as per the instructions and passed the wires through the transom and attached it to the plug. I have done this replacement several time before without problems.
However my digital trim gauge now reads -9 deg. Rotating the hex on the shaft makes no difference at the gauge. Unplugged the sender and re-tested only to find all is as it should be. I did notice that the same -9 deg is the reading I get even with the plug disconnected.
Anyone have any Ideas?
