My understanding is that the diffuser ring on a prop (that bell shape after the blades) is to create a low pressure zone behind the blades to help with exhaust gas exit, and to help keep exhaust gas from curling back into the blades and causing cavitation.
My questions are relative to stern drive boats that are running through hull exhaust - none through the prop.
what purpose does the diffuser ring serve in this situation? In most situations, the exhaust bellows or tube is removed at this point, and so ambient air can freely be drawn through the prop, however this could be controlled to a significant degree by capping the inlet (I think this would create more drag in the zone behind the prop) or (potentially) more desirably tuned by changing the diameter of thrust washer used (which would in turn restrict the airflow through the prop).
In short, does anyone have a good idea of how the diffuser ring (or lack thereof) on a prop impacts performance when there is no exhaust coming through the prop?
