Difficulty removing prop shaft seal + options
reginaldo
Im using a harbor freight seal puller and unable to make progress removing the prop shaft seal on a 2006 9.8hp Nissan outboard. The seal rubber seams really tough/hard and very much stuck around the exterior seal perimeter.
I have begun to damage the prop housing ass’y from prying.
Afaik the only other option to pull the seal is the “two screw” method which I don’t expect to work either.
What are my options here? I can purchase a new prop housing ass’y.
Additionally how is the prop housing part removed? It’s circled in red in attached diagram.
Thanks for any thoughts
reginaldo
After much trial and error successfully pulled the bearing carrier with 1/16" wire rope, double-looped on each side hooked up to a 2-jaw puller. This setup was stabilized with a 2x4 and standard clamps.
Furthermore kept the outer housing toasty with a heat gun.
