I have read the repair manual and watched YouTube videos. It all looks so easy, but it is whipping my butt! The drive shaft will not engage the upper unit no matter how much I turn the drive shaft (lower shift shaft in forward gear, turning the prop shaft counter clockwise), I get a "clunk" and it won't go any further. It is just short of the lower unit side studs poking through the upper unit holes. I am pretty sure it is not the water tube or the shift shaft (too hard of a clunk). The clunk is metallic and comes from the area of the drive shaft tip. What could be the problem?
Thanks,
Richard
p.s. This is the same lower as I removed for water pump replacement.
Thanks,
Richard
