stwilliam54
- Sep 1, 2001
- 5
I have a 1969 Evinrude Triumph 55 hp on a 15ft Arrowglass trihull. Just bought it in August and can't get it to run right. I have no top end power. It will run smooth up to 3/4 throttle but after that it will cut out and lose power. Here is what I have done so far--<br />new tank (yes the valve is open)<br />new fuel lines<br />new fuel pump <br />new lines from pump to carbs.<br />rebuilt carbs<br />changed points<br />wire insulation was severely deteriorated so put on new wire harness.<br />put on new amplifier box.<br />Checked compression (125-135 lbs.)<br />After all this still has same symptoms. Does run better at low end but still cuts out and loses power after 3/4 throttle, but if I pull on the choke it will run just fine at almost WOT.<br />What am I missing. <br />Can anyone out there help? Thanks.
