Different orifice plugs for bored cylinders.
ClassicV4's
[FONT=&quot]Should different size orifice plugs be used after engine rebuild? Cylinders #1 and #3 were bored .030 over. Cylinders #2 and #4 were kept standard. Work was done prior to me getting the motor. Cranking compression bounces to 120lbs on all cylinders. On upper carb the port side idle orifice plug was clogged with metal from cross-threaded orifice plug cover screw. Has #30 idle orifice plugs and #69(originally used #61) high speed orifice plugs. Upper carb #387123 Lower carb #386728. The #69 orifice plugs were used in 135 HP a few years earlier. Motor is seemingly in good shape. No signs of overheating. Not sure if the #30 and #69 combination is best since not all cylinders were bored .030 over. Need some insight and help on this! Thanks![/FONT]
emdsapmgr
The factory does not require that any re-jetting is required during overhaul with overbored cyls. up to .030 over. If you note, the factory always refers to overbores up to .030 over only. (that's as big as the factory oversize go.) Other manufacturers make larger oversize pistons. If you look on this board, you will see most comments regarding jet re-sizing start with pistons larger than .030 over. I've bored many at .030 over and have used stock carb jets with no adverse problems.
Faztbullet
That used to be the norm when regular gas was around, now with E10 it is recommended to up 1 size after .020 by nearly all the major rebuilders.
James R
I am not what you would call a major re-builder but for what its worth I have a lot of rebuilds out there and only on one occasion have i needed to up a jet size and that was for an idle sneeze on one cylinder that wouldn't go away.
ClassicV4's
Thanks "emdsapmgr," "Faztbullet" and "James R" for your help. In reading your replies it seems to me unless someone is going for high performance, quality fuel is an issue or some mechanical anomaly is present, it's best to work with what was originally equipped and go from there. Fortunately in this area, ethanol-free is plentiful. I'm just learning to navigate this forum and hope I can be of some help in the near future.
