Hi,
I have a 1988 mercury 150 that is the 2.0 version. I bought it used it is mounted on a tracker 1800FS. It runs really well WOT but really struggles at taking off. I got a Seloc manual and went through all the timing and it was off quite a lot. It runs better now but still bogs down taking off. So I started going through the carbs and have found something that isn't correct by the repair manual. The top carb is supposed to be an WH48 but all three are WH40 and all jetted the same. Do I need to try and find a WH48 or just re-jet the WH40. It smokes a lot at idle.
Any thoughts would be appreciated.
Rod
Rod
