I am running a 2005 20' Regal bowrider powered by a 350 Mag MPI with a Bravo One 1.5 outdrive turning a 14x19 Vengeance SS prop. The suggested WOT range is 4800-5200 and I get 52 mph at 4900 rpm under normal load - 4 persons plus gear. I know I fall in the range but there is room for improvement and I am willing to spend my money toying with optimizing my setup. I use this boat for cruising and watersports so I am looking for the best combination for all around performance.
I am considering a 14x17 4-blade SS Turning Point prop and this is where my questions lies. TP manufactures two of these 4-blade SS props - one is the 14x17 31501730 PA-1417-4 and the other is 14.5x17 31521730 VO-1417-4.
Aside from the obvious 1/2" difference in diameter, does anyone know if there are any other differences such as angle of rake, blade geometry, cupping, blade surface area etc.. that separate these two models? The TP website and hours of searching online have yielded no answers. I would appreciate any info that helps me make an informed decision.
