billbayliner
Thread starter- Joined
- Jun 30, 2006
- 553
Hello all: I am working on a 1986 Johnson 90 HP outboard for a friend and it has an issue of running strong for 5 minutes and then dying. It will still idle and putz along though. (This is what I am told and have not been in the boat while on the water)
It is hard to check out in my driveway with no load on the engine but I have did the basics including first checking plugs / gap and changing bad plug wires. I know this is not the issue but basics must be performed first.
Pulled the fuel pump filter and inspected and cleaned. Has a new fuel filter / water separater. Removed cracked fuel line.
Added some methyl hydrate to the gas tank incase water intrussion as this is a classic symptom of an inboard engine with water in tank. I told him to pull the fuel line and pop it in a fresh gan can and take it for a kick so we can pip the blame on contaminated gas or eliminate the issue.
I am not familiar at all with these 2 stroke Johnsons and thought maybe someone may have an experienced thought they could pass along.
I really do not want to spend a couple hours out on the lake in this cold October weather trouble shooting if I can come up with a possible fix with help from a member.
DAMMNN I just thought of something, plugged fuel tank vent. Will check this out but please post any other suggestions...
Stay tuned
Bill
Stay tuned
Bill
