Did I cause the problem myself?
sambluckie
If I over trimmed the lower unit, could the drive shaft assy cause damage to the bellows? The reason I ask is that when running boat at WOT, I can only get about 3800 rpms using the trim switch. I used the trailer switch to get up to 4100 rpms. Now I have a constant leak coming from what I believe to be the drive unit in the transom. Thank goodness I have an auto bilge pump.
If overtrimming caused my leak, is that why trim sending units are set to avoid this issue?
1985 Wellcraft
3.7 litre 4 cyl
Mercury Vengance 19" P prop
TilliamWe
Banned
Re: Did I cause the problem myself?
Overtrimming does not damage bellows.
Limits switched are there to keep you from ventilating the drive and over-revving your engine.
sharkin95
when was the last time the outdrive bellows was changed? probably either the driveshaft bellows or the lower shift cable bellows finally gave way.
CaptainMak
The question is WHY ? You very well know those buttons are seperate for a reason !
If you want to change RPMS (for whatever reason), get a different prop. Problem solved.
