dirtrybird
- Apr 18, 2010
- 10
I recently bought Mercury 7.5 HP outboard (between 1974-1976) from a guy who said he last ran it 2 summers ago. I got it home, sprayed some starting fluid in the carb and it fired up!
I noticed it wasn't pumping water but had to run inside for an emergency. About 10 minutes later I came out and it had shut off and, needless to say, was VERY hot.
I didn't try starting it again until I installed a new impeller and also some new plugs. I also sprayed the carb with carb cleaner from the local auto store. I tried to start it after all that but it won't stay running. When I spray it with starter fluid it runs for about 5 seconds and then stalls out. So far I:
- checked the fuel line to the carb and it's getting gas
- took apart the carb and cleaned it
- gapped the plug at .40
- cleaned the relays
Not sure what else to do at this point? It was running fine for that 10 minutes until it shut off. I think it's getting a spark since it runs for a few seconds but don't think it's getting gas. If anybody has any ideas what to try next PLEASE let me know! Fishing season is here and I really want to hit the water!
