Did I blow the inner wheel seal?
KCShorty
I replaced the bearing and races on both sides a couple weeks ago. The old bearings and races were toasted since the rear seal was letting water in. I got the proper double lipped seals. I have taken the boat and trailer out 3 times since. After the initial repacking I topped the bearing buddies till the cap rocked. I checked the following 2 trips and had to add some grease to fill them till the caps would rock. Figured this is normal since I had repacked them recently and the grease was settling. After each time of adding more grease, I checked to make sure no grease squeezed out the back, and all was good. I just got home from a hour long tow in 90 weather and checked the back of the wheels for the heck of it. There is a little amount of grease by the back seal and on the inside of the wheel. Did I blow the rear seals by adding to much grease? :facepalm:
Trooper583
Re: Did I blow the inner wheel seal?
I'd say you probably did. I did the same thing at the beginning of the season. Was a real pain in the butt to clean all the grease off the wheel. the inside seal blew completely out of the hub so it slung great all over the place. If you don't have that much grease on the inside of the hub then the seal probably didn't come all the way out. I usually just watch the bearing buddy tension spring and as soon as it stops moving I stop pumping. Honest mistake, just trying to make sure you had enough grease in that new bearing job.
bruceb58
Honorary Supreme Mariner
What is the condition of your axle where the seal rides?
KCShorty
I did take a look and clean where the seal rides. It looked to be fine. The prior owner had told me he had installed new axles in the trailer a year prior to me buying it. I have had the boat and trailer for 2 years now.
