Detent balls
Harker
Well..I think I am ready to put my lower unit back together. I lost the detent balls for the clutch dog and took the prop shaft to the hardware to see if they had some ball bearings to fit. The 1/4" were too big and the 3/16 look pretty small, are the factory balls in between these sizes? The motor is a 30 hp Johnson. Thanks....Lee
OBJ
Re: Detent balls
Detent balls have a habit of getting lost. They just disappear, never to be seen again.....until ya sweep up the shop.<br /><br />You should just get over to the Johnny/Rude dealer and order a couple....maybe and extra to. Off the shelf ball bearings won't work.
Harker
Re: Detent balls
I was afraid of that. We don't have a dealer anywhere close and the Shad connection is closed down for some reason.Forgot to order them when I ordered seal kit...DOH!
Harker
Re: Detent balls
Still closed when I went to checkout.They are the only place online That I have seen them.
rickdb1boat
Re: Detent balls
Works for me right now.. Takes a while to load..<br /><br />EDIT: you're right, closed until further notice when checking out. Sorry.
R.Johnson
Re: Detent balls
There is a special tool you are going to need to put those balls, and spring back in place.
Harker
Re: Detent balls
The Seloc manual shows a way of putting it back together without that tool...probably be REAL frickin fun. All I saw on the other site was Merc parts...are they the same? Not sure of the year of lower unit..it looks like it is the same as the "Pumpjet" lower I am replacing with it..it has the shift coupling behind the intake screens and the bolt holes match up.
waterinthefuel
Re: Detent balls
Sir this is not the forum for a problem like that. You need to seek medical treatment if your balls have detents.<br /><br />I'm sorry, I couldn't resist. :D
R.Johnson
Re: Detent balls
Harker: It is'nt all that much fun with the with the proper tool. You have to be carefull that you don't have a ball slip out and get behind the gear without realizing it. Have the case clean of all grease, and oil. When you feel you have the spring, and balls in place, shake the case to be sure they are not rattling around. You don't want to send one of those hardened steel balls through the gears.
Harker
Re: Detent balls
Waterinthefuel...I'm married...this is the second set of balls I've lost!Thanks for all the info guys....Lee
