johnnybigrigger
- May 28, 2003
- 141
Describe the worst/funniest repair you have found or seen on a boat. Plus, if you were the one who did it
. Share your reasoning.<br /><br />I bought a bass-boat on Ebay last year (P.T. Barnum was right), and there was a repair on the hull near the rear between the trailer runners about the size of a dinner plate. It was bare resin, and I could see the fiberglass mat underneath. I had to do a small repair on a crack that leaked near the chime, so I thought I would dress up that area before I spotted in the gelcoat.<br /><br />I started sanding, and I hit a gummy substance, and then the resin started flaking off. The gummy stuff was a coating of silicone over a small resin repair about ¼ x 2. This fool thought his repair was leaking, so he covered it with silicone, and then resin over the silicone! The leak was up from that repair about 8 in the small crack. If the repairman would have checked the hull for leaks by running water into it he would have found the crack in the hull.
