depthfinder
makdaddy
recently mounted trolling motor on bow and run depthfinder off same battery. running trolling motor and depthfinder at the same seems to affect performance of depthfinder. Is there an in line resistor I can get to stop the depthfinder interference, thanks
Silvertip
Honorary Supreme Mariner
Re: depthfinder
A resistor is not an interference filter. It is a voltage dropping device and something you do not want to do. Run the depth finder off the starting battery and you don't need to add anything. Or try running the locator wires away from the motor wires.
