Depth Sounder Cutting Out
Doin Nothin
My depth sounder (Humminbird) continuously cuts out. When in my slip it works and while cruising out the channel to the lake it works. When I get up on plane it stops working, but will come on occassionally flash the depth and then go blank again. Any ideas on how to rectify this problem. I have a thru hull transducer mounted ahead of my twin i/o's.
JB
Re: Depth Sounder Cutting Out
A very common problem with Humminbirds, DN.<br /><br />The fix is to get a Lowrance or Eagle with a Skimmer transom transducer.<br /><br />Moving to electronics.
bryanredfish
I had a recent experience similar to yours, and it was a very slightly corroded battery terminal/connection that was vibrating loose at higher RPM's. The cable would break connection just long enough to cut out the depth finder, and I'd have to re-set it. Might be worth looking at.
