Depth Reading Problems
rangersd
We just purchased a new Hummingbird 383c Fishfinder. We use it on a 18 ft Fiberglass boat. We are usually on the Missouri River where there are alot of sandbars pulling tubes etc.
Problem is the depth starts reading 0.6 when we get above 10 miles per hour. What could be the problem?
Barnacle_Bill
Re: Depth Reading Problems
The transducer is either in the wrong place or not adjusted right.
John_S
Do you have the tranducer mounted on transom or in bilge for a shoot thru hull? If transom mounted, a picture from the back and side would help us help you.
Silvertip
Honorary Supreme Mariner
Transducers need to be mounted so they are in undisturbed water while underway. If mounted too high, they lose contact with the water. If they are mounted in line with any strakes or rivet lines on the bottom of the boat, that creates turbulence. Turbulent water has air bubbles in it and the transducer can't shoot through air. It must also be installed so it doesn't flip up at speed. It should also be mounted as far away from the prop as possible and not on the port side of the boat.
gene8084
Transducers must be mounted with the trailing edge slightly lower (but not too much) than the leading edge. Most mounting kits come with shims and diagrams showing how much.
In case you missed it, Hummingbird has a good installation doc. (see pg 7) http://www.humminbird.com/PDF/wideonedeep.pdf​
rangersd
Sounds like they (the guys) didn't read the instructions. They mounted it where a previous Hummingbird had been mounted. The boats is stored 80 miles from us so when we do get back to it we will adjust and go from there. Thanks everyone for replying and I will pass on the info.:)
