Ristin
- Aug 4, 2017
- 58
I want to install a depth gauge in my 18' Seaswirl Sierra. At first I was looking at Hummingbird & Faria dash mount depth gauges with temp sensors. They seemed expensive. Then I discovered the Garmin Striker 3 & 4 which provide much more information and are cheaper. However I don't fish and the Garmin will take up a lot of space in my small console area. Then I discovered the Sonar phone that interfaces with Navionics which I use. I nearly bought one but then realized it connects via wi-fi to my phone. I have a wi-fi OBD2 scanner in my Expedition and when the scanner is connected to the phone, I lose internet connectivity. There is a way to modify the settings to make the phone use cell data for internet while remaining connected to the OBD scanner but it creates a 1-2 second lag between the scanner & phone causing the displayed data like RPM & speed to lag. I don't know if the Sonar phone would experience the same issues or not.
I'm sure there are pros & cons I have overlooked for each unit and I would appreciate your thoughts.
Thanks!
Thanks!
