Easyrider601
- Jul 30, 2010
- 9
I own a Tahoe Q8 i and the depth finder quit working. I also noticed the speedometer does not start reading until you reach 25 mph. any help would be greatly appreciated!
Sound like you picked up some trash in your speedo pickup on your drive. With your drive all the way up you will notice a small slot on the back side, make sure it is not partially blocked, do not blow air into this hole you will only push it in further . Try using maybe a paper clip to free the debre.
I have same problem with tahometer on my 195/IO - shows 2500 RPM all the time. Could it also be due to fuses?Check the inline fuse for the sounder and the speedometer reads off of pressure so they it won't start reading until you reach higher speeds.
Always 2500 RPM.What's it display once you turn the ignition off?
