Depth Finder - shallow lakes / no fishing
gonelong
I own a pontoon boat on a very shallow lake. The lake is at the deepest 15' in places, and is 2' in several channels, but mostly 4-8 ft in depth. For the most part I am pretty familiar with the lake and haven't been to worried about it. This year the lake is down 18" or so and I am more than just a little nervous in any of the channels around the lake.
My only concern is to find a depth finder that is accurate in these depths, and has an alarm that I can set for shallow water (say 3' or less). I am mostly only worried about the depth at idle speed (in no-wake channels around the lake).
If this unit also would have a fish finder on it, no problem. if its an in-dash model, again, no problem.
I have searched the forum and mostly I see people tallking about much deeper water than I will be navigating. Any firsthand experience with a suggested model would be great.
If I have missed a thread about this subject, please pass along the link and I'll happily check it out.
GL
MrBigStuff
Re: Depth Finder - shallow lakes / no fishing
Every depth/fish finder I have owned can do what you want. I'd be looking for the widest transducer cone angle I could find if you're limited to those depths. You don't need power as much as area coverage...
Silvertip
Honorary Supreme Mariner
The thing to remember about a depth finder is that it tells you the depth where the transducer is mounted -- which is also the area where the engine is mounted. So by the time the depth finder/locator has processed the soundings you may already have hit bottom. This is obviously compounded if you are traveling at faster speeds. A fish finder, even and inexpensive one, also shows you a picture of the bottom contour and is of at least equal value of the depth capability in that it can show you a slow or sharp rise or drop off in bottom contour. You can therefore follow a river or creek channel very closely -- even a narrow one. Eagle, Lowrance, Bottom Line, Garmin and Raymarine all have basic locators. Nearly all of them have alarms (shallow and depth). Look right here on iBoats.
Kymasabe
Silvertip has some good advice but may I ad another name to the pile of fishfinders. I've been very happy with my Humminbird fishfinder, depth has been accurate. Mine is a 10-12 year old Wide Optic, no longer made, but I think Humminbird proabably makes something similar. Decent and affordable.
gonelong
Thanks guys, will follow up on your advice.
GL
