Definitive Procedure to Adjust Elec Choke Merc 3.0 140
Jacalore
I've read thirty different variations on this, can anyone vouch for the correct procedure to set up the electric choke on a MerCruiser 3.0L 140? I'm struggling getting mine set correctly. Thanks!
Bt Doctur
Re: Definitive Procedure to Adjust Elec Choke Merc 3.0 140
when cold, adjust to closed position with a 1/8 drill bit used as a spacer.
achris
More fish than mountain goat
Post your engine serial number and I'll post the page out of the OEM manual...
Jacalore
6920736
achris
attachment.php
Jacalore
Thanks!
Jacalore
If the choke is set cold, (plate closed, or nearly closed) the setting is several notches away from the pointer... does this indicate a problem elsewhere?
Also, how long should it take for that coil to heat up and start opening the plate?
Thanks.
ktbarrentine
No prob... just a factor of the tension on the spring (age of choke, metal characteristics, etc). And...you need to make sure it is actually "cold" (ambient temp) when you set it. I usually cycle the adjustment through full travel either way to relax everything before going to final setting. I've been able to change the "notch" position this way and get it closer to the "book" setting (realize...the "book" setting is so called "normal", but isnt true in all cases for all engines due to age and other factors).
Choke should open w/in a few minutes to full open. Remember...you need to "set" the choke before starting, by opening the throttle full (full pump than back to start position).
Jacalore
Thank you all!
Muchas gracias!
Jacalore
Still experiencing probs. Set the choke, it opens almost immediately when starting. Got it running a few times but can't bring it down to idle speed without stall. What rpm is acceptable for warm-up (w/water Muffs on)? Thanks.
Jacalore
Ha! No, I'm running straight out of a fresh 5 gal can of gas.
But, I've got her running, and idling. Key was letting it rest for awhile, then a single pump and back, one OT ran for a few mins I was able to back off to idle and eventually she smoothed out. Took several mins for plate to open, completely. Several off, wait, on cycles started ran smooth - idles around 1300, is that close to norm?
Jacalore
Seems to starting ok now, choke performing as it should. Thanks everyone.
Idle is a little rough below 900 rpm, but I'll work on that next time out on the water.
achris
Idle should be around 800 out of gear.
Don S
With a 3.0L, you better get the idle down below 750 rpm in neutral or you will be having a dieseling issue when you try to shut it off. Even 750 van be iffy.
Jacalore
Ok, thanks. This has to be done on the water, correct. Carb idle adj and fuel mix? While in gear, idle speed?
Don S
No, it can be done on muffs and be very close. If you put it in the water and it needs a little tweaking, go for it. Trust me, with over 25 years of being a boat tech, I didn't take them all to the water to adjust them. Don't even recall a problem unless I did something wrong to begin with, and believe me, I have made my share of mistakes over the years.
airshot
Yep...them chokes sometimes have a mind of their own. Followed the manual to a T and still had to fine tune it a bit. The manual got it close, my dog house is easy to remove so each trip out I made small adjustments until I got things just right. These things are mass produced like most other parts and no two are exactly the same so some minor tweeking may be in order. The manual is great for getting things close.
Jacalore
Thanks, guys. This forum is amazing!
