Re: Deck to hull joint..
my last built boat was a 'stich & glue'.. the instructions called for a rough cut floor..at least a 1/2 in. gap allthe way.. <br /><br />a tite/snug fit was not wanted an un-desirable...<br /><br />said to/i did,, apply thick handmade epoxy putty..usin' 75 % silica,, 15 % microballoons an 10 % milled fiberglass..<br /><br />layed putty,,, than mooshed layed the ply floorin'..<br /><br />what mooshed over ,,i used to make fillet..<br /><br />a layer of 8 in wide biaxial cloth layed in half.. half (4 in.) on the floor.. 4 in. on the hull.. <br /><br />than layed another biaxial... 6 in. wide .. again in half ... 3 in. an 3 in.. <br /><br />as per to have a 'stair stepped'/ tapered effect ... so as to better'feather edge' <br /><br />then mix up more putty to use as 'spackel' to hide to the cloth.. an sand smooth to hull & floor..<br /><br />careful not to sand into the cloth as to degrade the strenght of the biaxial..<br /><br />see,, the tite fit was undesiriable cause it takes the putty to surround the joint as to be a component in the 'composit'..<br /><br />AMMENDMENT ::<br /><br />when making 'SPACKEL' putty,,, use a 75 % microballoons an 25 % silica mix.. this is so it can be sanded readily... if not,,( boy,,are you in trouble ),, it'll never be sanded..!!
