85_celebrity
- Oct 2, 2007
- 28
Ok I find this site to be the place where I go to find the textbook way to do things. A.K.A. the right way. I have cut the floor out of my boat ( 1985 Celebrity 190BR open bow) After I pulled the floor out I found some of the stringers to be wet almost to the point of saturation but not rotten. Should I cut these out and replace them or just dry them out and glass over them (they aren?t glassed in now). Also I am to the point of buying materials and want to know what type and weight of fiberglass should I be using? What type of fabric and weight also what type of resin? And what is the best way to apply it? I know this leaves a lot open for opinion but I want to hear other people?s opinion as long as they also state the theory behind it. Also leaving out treated and marine plywood what is the most commonly used type of wood for decking? Also what is the best way to tell if foam is saturated? I have some foam I can stick a screwdriver in and it comes out wet but other when I do the same thing come out dry as a bone. Should I take it all out and replace all the foam or just the foam that is wet with the ?stab test?? Also when I pulled the carpet up I saw that they just drilled holes through the floor and poured the foam through the holes. Is this the preferred method? Or should I pour all the foam and cut down what expands above the stringers? I really don?t want to drill holes in the new floor if I can avoid it. I guess I could lay the floor, drill the holes, and then glass over the holes when I glass the rest of the floor. I want to do this the best way I can because I don?t want to it again. I am a firm believer that if I don?t have time to it right I definitely won?t have time to do it twice. I love this site it makes it so that I can continue boating on budget.
