I have seaswirl striper 2600.On both the starboard and port side at the stern of the boat where the hull deck seam takes the corner from the sides of the boat the transom there is a leak.Fresh water leaks in a small stream when it rains.It is right at both corners , right at the hull deck seam.My question is does anyone know what I will find if I take the rubber insert of the rub rail off from the center of the transom( where it ends) to the corners.My thoughts are that there might be a screw that fastens the metal part of the rub rail to the boat and I might be able to reseal these screws if thats where it is leaking.I have tried to seal from the inside with SIKAFLEX but it did not do it.Does anyone have any ideas?Or any product that might work to seal this leak.Sorry for long post<br /><br /> PT
