roscozen
- Mar 8, 2008
- 98
i need to provide a solid base for these poly tanks. pics show the tank at its' correct placement as well as the angle of the gaposis needing to be filled . the foot must be supported square. the deck is fiberglass and slopes down to the left and away, and is also unevenly bowed downward in the center of the tank. i will be mounting this tank on a 2x8 and will use 2" transom straps to secure them from the 2x8 to the top as the mfr. suggests. additionally, i may very possibly build a plywood enclosure around it as well, once secure.
the question is this,
what can i do to level the gap between 2x8 and the existing deck to provide a solid base for the 2x8??
