Deck Drain - 2000 Starcraft
zabitac
I also have a deck drain problem on my 2000 Starcraft 20 ft deck boat. The drain just under the floor storage compartment drains from the left front lower side of hull. However, water also comes in at the same location if I have 3 or 4 people in the front of the boat. If the boat is sitting down in the front, the water may keep entering until I speed up and push it to the rear where it's pumped out. There's only a plastic thru hull fitting, a black corrugated hose and another plastic fitting just under the floor compartment door. I either need to install a scupper valve somewhere or a manual valve that I can stop the water from entering. I would like to know what is recommended.
