Re: Deck boat trolling motor
I attached the minkota quick release puck to a 10"x22" piece of 3/4 inch plywood and the mounting plate to the motor. Then attached the plywood to the bow with 4 screws. I had to cut a piece of the lip of the anchor storage compartment with a dremel and tungsten cutting bit to gain access to the underside of the bow. Then I made two notches on each side of the plywood at the front and used a ratchet tie down fed through the notches and attached to the exising trailer attachment hook lower down on the hull. So I can attatch the plywood with the 4 screws, which secures the back of the plywood, and the tie-down secures the front of the plywood after ratcheting it down nice and tight. Oh, the 4 screws are secured with wing-nuts under the bow and I used the rubber bushings that came with the motor hardware under the plywood. Once all secure, I simply drop the motor on to the puck and secure with locking pin. The motor is a PowerDrive 24V, 62 inch shaft, with i-Pilot. The whole works is removeable so no motor in the way when tubing and skiiing. Works like a charm!
