Decal removal, oxidation removal and polishing
opto55
Last fall I purchased a 1988 Campion fishing machine. I want to remove the old decals, oxidation and polish the exterior. Can I buy new decals and where would I find them? Also what products and procedures should I use to remove oxidation and polish the hull?
Thank you.
jwellcraft
Re: Decal removal, oxidation removal and polishing
For the oxidation removal you will want to wash the hull clean, use a rubbing compound (3M is very good) then some good polish and then a good wax (collinite has a great insulated wax) to make it last and protect it. You may want to use a varible speed buffer if it's heavy oxidation but otherwise some good elbow grease.
Dawg'sLife93
You can also wetsand the boat with 1500 then 2000 then 2500 grit sandpaper, then rub,polish, and wax. It'll slick her up real nice.
